It's time to build another truck
Surprise, surprise: blue King Hauler
I need a 6x6 to pull the big dump trailer on sand and gravel. This build will use a RC4WD R2 gearbox, with a LRP 12V TP II motor.
The truck has a bit of a lift, so I had to make some brackets to keep the driveshaft from falling out in severe conditions:
Since all the diffs will be locked, weight in the front is needed to be able to steer
