Old 12-26-2014, 11:05 PM
thebigo thebigo is offline
Default Re: Tech help needed
Couldn't see you pictures but I watched your video. Mavric is right only one wire for powering one ESC is or should be connected to the reciever, allthe other poer wire's should be disconnected. I would probably guess that the ESC with the hot wire is the ESC that runs the pump. The ESC that is in the heat shrink sittting on top of whatever, is the pump ESC. When you turned the pump on I heard nothing, tell's me that the ESC is not workin or the Motor is not working? So you need to test that ESC first and see if it is delivering power to the motor.
On the Esc for the pump you have a black wire (ground), a red wire (to battery or Hot), and two wires to the motor (different Colors). need to disconnect the wire's running to the pump motor from the ESC, and turn the pump on, then hook a volt meter up the wires see if you get any kind of reading when you move the sticks on the transmitter.
If anyone else on this post see's i am leading him wrong please help!
