Old 07-21-2015, 08:32 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: Scaleart - assembling an Arocs 8x8 roll on roll off kipper
Originally Posted by apfubar View Post
Well done!
On the charge port, I would suggest checking if you can get a right angle plug of the same size... Typically they are a bit shorter...
On the sound, I am sure you will get it sorted, more than likely it is something simple... Wrong plug or wrong direction etc... There are lots of wires in these things... It's really easy to get a couple wrong first time around! :-)
Let us know if you want us to review how it is connected... Pics and diagrams will make that relatively easy...
Cheers,
Ap
Hi Ap, not too worried about the SMX, as you say, probably have reversed a plug somewhere. In the next couple of days I will check up on the wiring in the cabine and take some pictures of how I plugged what in where. Maybe I'm too close to it to see where I might have gone wrong.
Good idea about the right angle plug for the charger! Meanwhile succeeded in charging battery by using some crocodile clips - bit iffy but went OK. Battery does get very hot though.
Ahhh...
Just looked at your jumpers on the SMX...
Check the manual, on the bottom of page 9... I think you have the smx in setup mode... If you haven't changed the jumpers since you took the photo... In post #108...
Cheers,
Ap
WOW, you went back to check .. thanks for that! ... The jumpers at the moment are per the manual in setting 1
When I tried to turn change the programming on the SMX, nothing much happened ... supposed to get the air brake sound, but nada ...
Thanks again for giving it some thought! Really appreciate that!
Stephan
