Old 02-13-2016, 06:22 PM
Prop Shaft's Avatar
Default Re: Capo 1:8 Jeep CD15823
Painted the covers I made. Im attaching the drive shaft tunnel with scale hardware and the transfer case cover is glued to the transmission tunnel.
Then tackled some wiring. This is going to be the hardest part of this build, especially when I get to the engine bay. Using boxed styrene as wire chases, and two sided tape to attach to the inner quarters.
I found some boxed styrene that fits inside the rockers as well. These have to carry the 6 led wires as well as one of the battery wires. It was a tight squeeze getting the wires fed through.
A look at the painted fender flares.
And the mess that is my work bench.....
