Old 02-18-2016, 09:04 PM
Prop Shaft's Avatar
Default Re: Capo 1:8 Jeep CD15823
Small update. Spent a few hrs tonight working on the dome light. Made a lens from some clear styrene.
Then I used more boxed styrene that fit snug into the top of the roll bar for a place to mount a switch and an led, as well as a wire chase.
I slid various sizes of styrene strip into the boxed tube and glued them in to lock everything in place.
Masked off where the lens will be.
Painted and glued on the lens.
Mounted into the roll bar.
Now I'm just left with a mountain of wiring.... The plan is to conceal as much as I can between the dash and firewall.
