Thread: 966 update
Old 05-20-2016, 06:21 PM
Cat966c Cat966c is offline
Default Re: 966 update
Basically I am running 4 of these in my Bruder loader and compactor. https://www.pololu.com/product/1586 I buy them from eBay though because it is much cheaper. If you want more power you could go with the high output version with a slightly lower ratio. https://www.pololu.com/product/1577 The last ones are powerful enough to destroy their own gearboxes if locked up on 7.2v. I like the less powerful ones for this because they will stall without breakage and that also helps with steering.
Thanks!!! So a few questions: if I got the high output would it make it slower? And the last ones you mentioned are the 12v?? So I couldn't use them on a 11 mah battery? And if you're running 4 of the motors like you said, that means four esc's right? And what's an encoder? I saw that they have an option to come with one. Is that the thing that connects to the esc and/or receiver?
