Old 05-26-2016, 03:22 PM
Kaan's Avatar
Kaan Kaan is offline
Kaan is on a distinguished road
Default 1250$ 1/12 Scale RC Hydraulic Loader METAL and RTR
when I was doing some research about rc4wd bulldozer on aliexpress, I found out about this
Metal and RTR for 1250$
1. Dimensions: 53 cmx22cm x27cm Weight:15kg
2. All carbon steel production.
3. The brushless pump pressure of 4 mpa, theoretical maximum lifting weight 13.5 kg
4. All products are the standard tensioning crawler device, automatic tension! The clay sand moving not card master.
5. Contains oil cylinder x3.
6. A full set of debugging, contains rich, 6, 2.4 g remote control. Players should bring along their own 3 s 11.1 v battery.
What do you guys think of that? There is a video also on the link.
