Old 08-02-2016, 02:51 PM
TRUCKMAKER's Avatar
Default Re: All wheel drive truck
Do you have a GRU and what reduction does your T-case have? Are you going to use it in soft dirt or sand? You want to be able to have wheel speed if your in softer material so the questions above make a big difference. Outside of the speed if you don't use a GRU the stock can is fine and it's even better if you end up with a lot of reduction.
