Old 08-29-2016, 09:48 PM
Cooper's Avatar
Cooper Cooper is offline
Default Re: Major glitching on 2.4 gHz
Originally Posted by thebigo View Post
Sounds like you have a servo malfunction. Check for leaks off of any hydraulic connections, especially around or near servo's. I am almost 100% sure it's a servo short circuit.
David
I agree with David, had same problem before. Sometimes the oil can leak into circuit board through screw hole that is normally filled with a screw for the servo horn. Mating to the valves eliminates the horn leaving open path for oil. Or simply around spline. It's not any interference from external sources, it's probably feedback interference. Unplug one servo at a time from rx and operate for a bit, see if one (or possibly more but unlikely) gives that interference. And if not servos keep testing anything else like track esc's or turn esc.
