With swapping motors I need to make a new motor mount. But the bulkhead is fitted into the frame. I'm going to make a bell for the motor to fit into. This will allow me to get motor closer to universals and a direct fit to the universal. Before I had an adapter from the 8mm motor shaft to the driveshaft. Just some pieces of stock to make part out of in the background.
And also got new pieces of acrylic/plexi?  Also with the proper adhesive. Reason for remaking tank is it has a leak in it and the fitting side will be a little thicker.
