Old 10-06-2016, 04:17 PM
Fourth Protocol Fourth Protocol is offline
Fourth Protocol is on a distinguished road
Default Re: Mercedes Benz LPS 1418
Right, progress. I'm about 3 weeks into this build.
Ordered a Tamiya Hilux High Lift kit from Hong Kong, and built it. I sized the build to the track width of this kit (220mm), which pegs scale at ~1:10½.
Didn't bother with things like servo covers, electrics tray and battery holder, as I'll make my own. Then I started on the cab.
Cut out some roof ribs, and notched them so that they'll slide into each other to provide accurate contours.
Dry-assembled it...
...and put a skin on it.
That 2mm base plate is coming off before it goes on the body, but that aside the roof is done.
Styerene at bottom right is a little thin and needs surgery...
Next step was to get the cab mounted on the chassis. Also cut out the grill, and played with some tyre/tire (delete as appropriate) sizes.
Which brings us up to date, pretty much. More to come as it happens.
