Old 10-09-2016, 08:26 AM
komatsu97 komatsu97 is offline
komatsu97 is on a distinguished road
Default Bruder dozer servo help
Evening all,
I have converted a Bruder D5 Dozer, using a sabertooth controller and an old rc plane transmitter. I used the elevator and rudder stick for directional control, and the throttle for the blade control so I can hold a desired height of the blade easily, as it is not spring centered. I have decided to use a servo to angle the blade controlled by the aileron channel (left and right on the throttle stick). the question I have is how to stop the servo from self centering, for example; Angle the blade to the left, and let the stick spring return to center, but the blade stays in that position until i move the stick again.
Any advice would be appreciated
Cheers,
Liam
