Old 12-12-2016, 10:51 AM
gmmiller06 gmmiller06 is offline
gmmiller06 is on a distinguished road
Default Re: 4200XL hydraulic issues
I've checked radio settings and all seem to be correct. The servo is set to move 120%. I did center the servo up before installing into the valve. I put the set screw back facing down towards the hole in the bottom of the valve block just as the others are. I am going to try draining all of the fluid and refilling with fresh. I had been using 32 oil and it was working great before the servo issue. Or at least I'm guessing it was a servo, it could be the tx/rx giving me the issues. I also want to drain it because it is possible that I over filled the machine with oil.
Hopefully after work today I can get it going or at least narrow down my issue.
