					Originally Posted by  tracksntreadslou
				Wow Joe looks good .curious to see how well the glue stands up..I wonder if there is a way of cleaning the adhesive off if needed ..sure if you wanted you could tig weld some spots .good to see you in the shop making stuff ..Like the new welding table ..will help to keep a good steady hand .
Hows is the weather co-operating .I may have to make another road tip there soon ..I will keep you posted
 Methel ethel keytone, should cut the glue, or heat it.
Cheers!
