Re: Will a Wedico tri-axle wrecker "crane" fit Tamiya?
			Yes it can fit you 24-6mm wider than standard I made to fill in pieces from plastic card the other issue is the wheel arches do not line up so either you need to cut the stock sides or re do them in plastic sheet which would allow the addition of more details storage boxes etc....
Bob
