Old 05-21-2017, 04:03 PM
Rimrock Rimrock is offline
Default Re: O&K Damitz RH6.6 Big OilPump 750ml
Originally Posted by trucker1970 View Post
Take my advice, that's not a setup one want in a high end machine.
The pump itself, HR7, is top notch, used by Premacon and others, but with Magoms setup there are taken some 'short cuts', in order to keep the price that low.
Better take a look at Premacon's setup with the HR7, 900ml. They got the motor and planetary gear-drive as it should be. An issue is size. Your machine is quite compact. most ideally would possible be the 750ml Damitz pump?
Soyland Industrier
