Old 08-05-2017, 10:06 AM
TRUCKMAKER's Avatar
Default Re: Grand Hauler Bearings
You also need to consider where and how your going to run your truck. If you run in any kind of moisture, i.e. wet Roads, puddles etc. you will want to stick to bronze bushings. Moisture in the bearings can rust and lock up the bearing, unless you pull them out and dry them. I have both in my trucks and can't tell the difference in operation, I also don't run in water.
