Old 10-19-2017, 07:32 AM
Default Re: Hooded Daf 2800 european roll-off
this topic needs an update. several thing have changed after the last post.
but the truck is also going to get an overhaul. the cab's paint is not going to get refreshed.
after being the workhorse the last few years it collected a lot of dust, lose or even broken off parts.
most other things will be moved. replaced or finally painted.
the biggest thing is the position of the electronics under the hood is going to be moved to a spot along the frame. the servo driving the chain is going to be replaced with an micromotor. now its a3 kg servo. it will a 16kg micromotor. not that the 3kg isn't enough. the micromotor is smaller. more like the size of the real thing.
the chain to pick-up the skid need some work. It will still be that workhorse. but it will look a bit better.
I'll tahe and post a lot of pictures
