Thread: KH Beam Hauler
Old 01-17-2018, 08:52 PM
Bo Wallen's Avatar
Thumbs up Re: KH Beam Hauler
Not a stupid question at all. Thanks for asking. Most of the transport is done on the road......when you come to a construction site things get a lil tricky. Some sites spend a bit of planning and grade a decent entry some don't. In this case i was a bit curious how well or not this setup could access different arias. I got stuck a few times....ugh ! The bumper on The front of The BO-Dog is a bit to low for off road. and just standard Tamiya axles and tires does work quite well. Next time you see this one, it will be equipped with Lesu axles and diff lock. New Motor and ESC is also needed. Flaggs and marking in general was missing....Running out of time as usual before a meet. When moving things on special permit things get a bit interesting an some normal rules goes out the windows. The extension-rod on the truck is retractable by a little motor under the frame, so i can pull normal trailers too. Hope this clear some of the questions.
