Thread
Fumotec 490
06-16-2019, 10:44 AM
calum_scania
Re: Fumotec 490
Well it lives again
Everything connected up, oil in the tank, bled it up and checked for leaks - so far the only one was a return pipe to the tank which was a quick fix.
I've been painting interior parts in the meantime - a mixture of airbrushing and hand painting
Also last weekend got the final coats of yellow on the door and cab, those were clear coated and left to harden up. I've given them a light grey colour inside. Next job will be to glue the windows in and mount the door
And yesterday it was time to test it out, just some light digging whilst I set pump speeds and pressures. I mainly just wanted to see how a trial went, lasted nearly 1 hour on a 5000mah battery which I'm happy with
Then as the battery was coming to an end my swing stopped working
soooo thats was the end of that, packed up and back on the bench I removed the motor and gears to find a grub screw loose... A dob of Loctite and back in it goes!
calum_scania
View Public Profile
Find all posts by calum_scania
