Old 06-21-2019, 09:23 AM
Papy Papy is offline
Default Re: Help modify a king hauler with MFU
Originally Posted by James007 View Post
Great thanks, I already have the tamiya mfu, so if the speaker box is removed is there much difference in sound ? Cheers James
That does not make a huge difference to me....I personnally use to put the speaker behind the hood grill
As for shortening the sleeper, that's really a basic...I can just suggest to use adhesive tape to mark accurately the part to be removed, then use a fine saw (or a hobby knife....gives cleaner cuts, so less file work, but much more dangerous for the fingers). Better position the tape on the side you will keep.
When you get your two parts, glue them together using some thin plastic stripes inside to align and reinforce the joint, and eventually body putty to fill the remaining gap.
