Old 07-28-2019, 06:44 AM
kingbob kingbob is offline
Default Re: Movie Optimus Prime build
Originally Posted by James007 View Post
Hi bob, can I ask what you used for the rivets on the body ? Thanks
I actually used pinheads. Drilled small holes with a pinvise, put the pin through and glued it, then cut off the bit inside.
If i was to do it again though, i wouldn't do it that way. Externally it looks fine, but inside even with the pins cut, theres lots of sharp bits and i cut myself many times, and it can scratch parts when putting the body on.
Now i'd probably just use some round head resin rivets. Not as cheap as a pack of pins, but neater internally.
