Old 05-07-2020, 07:39 AM
kerst's Avatar
kerst kerst is offline
Default Re: Euclid R-62 dump truck
Originally Posted by ddmckee54 View Post
With the gear ratios you've got in the transmission what are your scale speeds?
I think you said you tried to stay close to the original ratios in the transmission, but the difference between your electric motor's max RPM and a diesel's max RPM could be why you need more reduction.
With the current gear ratio top speed in scale 1/1 is around 25 mph. The real one can reach about 30 mph.
The electric motor should reach 5,500 rpm, while the diesels do 2,100 rpm.
Kerst
