Old 12-24-2020, 11:23 AM
Stuff's Avatar
Stuff Stuff is offline
Default Yard truck build out of leftover parts (mostly)
You know that feeling when you go through your parts and think "hey, there is enough here to build a truck"... yeah I thought that to lol. Most of the build is possible because I bought the wrong rear axle bag for my Scania build this year. (single axle vs tandem axle d'oh!)
So started with a Highlift Frame. More similar then I thought they were. I used the front and rear crossmembers from a highlift parts tree I had.
Mounted front and rear axles to the high lift frame and then mocked up the cab. Thought it looked pretty good! Fronts are just temps. I have the tires but the wheels I thought I had turned out to be outside duals.. So I had to order those and with Christmas, yeah I'll be waiting..
I mounted a step and made sure the cab sat somewhat centered on the front axle.
Mounted a fuel tank on the driver side (yeah I know it is backwards but the frame is missing some material and it just worked better this way)
Mounted up the steering. Used parts from a crawler. I think the springs are from a crawler to or something lol.
And so far this is where I am at. Waiting for wheels for front and a motor/gear reduction to show up.
File Type: jpg 6cY0imeQ.jpg (157 Bytes, 89 views)
File Type: jpg LuEdB9sg.jpg (157 Bytes, 89 views)
File Type: jpg mcBZFBpw.jpg (157 Bytes, 91 views)
File Type: jpg tmZ-1hGA.jpg (157 Bytes, 90 views)
File Type: jpg uKos9Rrg.jpg (157 Bytes, 91 views)
my YouTube is -
Subscribe!!
My Facebook -
