Old 01-20-2021, 09:06 PM
Default Re: New Year--New project
For the holes I used some plastic diamond plate and used simple silicon caulk to glue it on, did the same thing with my Delta loader. I'll make some kind of cover for the outside too, just not sure how I'm going to do it yet.
I used the dual micro servos for my bucket tilt and the HItec D954SW servo for the lift. I think if I did another one I'd lift from the front of the servo instead of the back ( if that makes sense) then the lift arm would be less visible and you wouldn't have to cut the rear cover so much. I could probably change mine but it works pretty good so I'll go with it.
