Old 12-10-2023, 04:21 PM
Fury Fan Fury Fan is offline
Fury Fan is on a distinguished road
Default Re: Hercules flatbed trailer with skids of drywall
For the Doepke grader, I was simply planning some modern 1/10-size tires that look somewhat correct (I was very selective on the tread/sidewall pattern) and adding a cab to it, some exhaust-pipe detail + maybe a set of lights. No RC action, too much engineering required at this time. And new paint.
The Nylint roller will get a muffler and air intake setup, the cab is done, and a new paintjob. No RC here either.
So I got around to making a pair of straps, and they confirmed what I was planning to do anyway. To make them pulled slightly tight, it caused the skids to move. I was planning the next design of drywall skids to be glued together into a solid block of 4 skids, so the straps merely confirmed that. In the picture here, the skids were re-adjusted into a good position.
The straps are a PITA to make. De-burring the brass flats, bending into a hook, threading the elastic, folding it and putting 2 pieces of heatshrink on it. 1 strap is burned a little from the little micro-torch, the other one has an imprint from where I flattened the heatshrink while it was still hot. Better methods are needed. They seem semi-durable, at least. I need a better option for the brass hook, one with less CNC and debur time. I am thinking of making them from brass flat and making the whole hook the same width, and then just CNC-ing the slot for the elastic.
