Old 09-24-2024, 11:47 AM
Default Re: 1/16 Scale FrankenDiff
With your growing lack of tolerance for fighting the printed part tolerances: What if you rough assembled the axle guts, moderately warmed them with a heatgun, and tried to close the axle case halves around them? Let the parts soften and clearance what they need, then you can evaluate where it made marks.
Which style WPL axles actually have a Differential instead of Spool?
I had wondered how much the extra bearings in the wpl axles was there to stiffen up the cases instead of support the axles?
