Old 05-03-2011, 08:58 PM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: Oshkosh Het M1070, M1000
Made a little more progress this afternoon.
I will be changing out the socket head cap screws for button heads. I need the scoket heads for the crossmember installation.
Attached the rear section frame mounts and axle supports. Used a .125 punch to help align the parts. Worked pretty good.
One thing I do not like is that the aluminum gets marked easily. I will have to disassemble everything and clean the parts up after everything is worked out.
Thanks for looking
File Type: jpg Suspension right side View rear section 640.jpg (49.1 KB, 116 views)
File Type: jpg Suspension Top View rear section 640.jpg (48.8 KB, 83 views)
