Old 11-21-2011, 11:32 PM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: Pete 357 tri-axle dump Video added!!! 11-20-11
Originally Posted by rockNmayhem View Post
Brian the truck looks like it dumps great and very smooth. The only thing I noticed was that when under a load with the hyd's it seemed to dim the chicken lights on the cab. I'm not sure if it was the camera adjusting back from movement or is it really pulling that much power?
Tyler
Thanks! Ya, your right Tyler. The esc for the pump is drawing some amps while it is dumping. Then when it reaches the top of the stick the lights almost go out. The battery was a little low for the vid. When the battery is full you don't notice it as bad.
Brian
