Old 01-07-2012, 05:18 PM
Brel's Avatar
Brel Brel is offline
Default It is a hook lift truck
I have a Tamiya Mercedes delivery truck on the way to me from Hong Kong
also got a set of Knight hauler frames and middle axle for a 6X4 truck
I am going to use the knight hauler frame rails for the trucks chassis and use the original frame to re jig the front end of the frame to suit the European truck wheel base and use the rear axle and the middle axle to make it a 6X4 truck chassis and either build the upper body as a rigid tipper or buy a hook lift system to make it a tipping hook lift truck, I intend to use the Mercedes cab and mount the gearbox as per delivery truck with it under the cab as far forwards as possible
parts so far
1 complete pass through driven axle
1 set of dual axle suspension
Carson steering rod
blue bird low profile servos for steering and gear changing
on order
the delivery truck kit
the c parts for the dual axle
MFU 01
short prop shaft to fit between the rear axles
paint for cab (it is going to be red)
to order
hook lift kit or a tipper body and hydraulics to suit the tipper
new prop shaft and centre mount if I have to buy two shorter prop shafts ( don't know the distance between the gearbox and front differential yet)
Last edited by Brel; 03-28-2012 at 09:17 AM. Reason: adding part to list, changing topic title
