Thread: Knight Krawler
Old 12-01-2012, 09:12 PM
TRUCKMAKER's Avatar
Default Re: Knight Krawler
Originally Posted by dabears View Post
Chassis looks great!! Love that color of Blue! I bet that color really looks good out in the sun!! Cant wait to see more progress!! What did you use for your lift axle?
Thanks Aaron, the chassis will get another coat of blue and a coat of clear. The lift axle is a trailer axle that I cut the center out of just inboard of the inner most bearings/bushings. The center was replaced with 2 pieces of brass tube which the trailer axle sections slide into. I formed a u shaped piece of brass and soldered between the tubes. Then I formed a truss out of brass and soldered it across the top of the u and the tubes. Covered the rough edges with a little filler and primed it. I need to clean it up a bit and top coat it.
