Old 02-24-2013, 02:44 PM
catmack catmack is offline
catmack is on a distinguished road
Default Re: Possible Solution For Tracked Equiptment
Originally Posted by Trucker47 View Post
I'm going off this picture and some pictures of the vario tracks and it looks like they have a very slight taper. other than the tailing face of the last grouser has a greater taper. Also if I was to taper them it would really increase my machining cost as they would either need to be machined on a 4 axis machine with a tilting head of just have multiple passes using a ball nose which would take much for time than a few passes with just a 90deg endmill. And im sure you know, time is money!
I may make another grouser pad just like this with more some details and see what machining cost will be.
I got en e-mail form my machine shop today and they said they are just wrapping up the quote and should have it within a day or two. I may send them another grouser pad that is a little more scale and complicated to see how much it will cost.
But the good thing is, is that if this pitch that I am currently using is what you guys can use then I can make multiple different grouser pads that will bolt onto the link with just unbolting the old one and bolt the new one back into place making this a very universal system!
Chris,
I agree, making a unit as universal as possible is one of the most important things to keep in mind. What kind of steel did you have in mind? In the photo, what size machine is that? Colin
