Old 02-27-2013, 04:17 PM
Default Re: Any body use this on the king
I have installed the Rigid suspension that is real similar to this one and I will say they are nice. Now if you plan to use this style suspension I do suggest you get their axles or be prepared to modify the Tamiya axles. Modifying the axles is not bad it is only drilling one hole. But you must get the hole in the right spot or the springs wont sit on the axles correctly causing them to bind.
Travis
