Old 03-28-2013, 01:07 PM
kaptain Jack's Avatar
Default Re: Millling machine question
Yes you can,but milling machine is mostly for shaping parts,you can do precise drilling on the drilling press, if you measure accurately and use a center punch to mark your holes (you can buy them spring loaded for under $10), also, start with the smaller drill bit and then enlarge the hole by switching to a larger.
Hope it helps.
