Old 03-30-2013, 09:58 AM
You betcha Nathan, that steel bucket is very noticeable with its additional steel weight, but even moreso with its 2.25" longer depth (@5" total), add to that the BB's in the tires and jacking up the pressure from 12bar to 17 bar, tilting the bucket down won't lift the front tires off the ground anymore! Chances are the bucket cyl needs to be replaced, the oil might be slipping by the piston; the seal drips a bit too... I need to change all 5cyls on this loader, as they all seep a bit... what a mess it all makes!!! However, the twin loader arm cyls have zero trouble lifting a bucket full quickly with the higher pressure.
Got it Joe. Thanks. How many hours have you got on the WA500 now? Any idea what the weight is, with BB's in the tires? Seems a pretty darn robust machine, for all the work it has done. Do you notice the wheel motors getting tired, from the extra weight in the tires? Pun not intended!
