Old 05-09-2013, 08:01 PM
apfubar apfubar is offline
Default Re: 4 Axle Low loader
A couple more photos:
Behind the Aeromax
Unloaded Suspension - note the gap. I had to move the suspension mounts for more travel so the axles don't bottom out on the servos or frame.
Loaded Suspension:
Gooseneck with box...
More Euro look with the rear tyres covered etc.
Suspension, axles and servos:
Full lock:
Side on showing how much I have raised the spring mounts:
All loaded up:
On the todo list:
- decide what mods to do to make it "Australian"
- complete the mounting of the ramps and deck
- add something to stop the decks from over widening
- mount the lights(inc beacon) and other items
- Wiring up the lights, neck and the steering servos
- rotate the springs so they are trailing on the slippers rather than leading
- correct the geometry of the wheels(toe-in, and steering angles)
- ideally change the suspension to add in equalizing
- paint.
- add signs and other items.
Then onto the dolly...
Cheers,
AP.
