Old 05-26-2013, 12:53 AM
Default Re: Days you wished you never got out of bed..
Originally Posted by hvy 1ton View Post
Not much left of that truck. What a shame. Gotta ask, why the big rubber on the lift axles? The few quints and supers here run the little tiny wheels/tires on the lifts. Most Quads are setup like that tho.
Those lift axles are rated around 13,000lbs with lo profile 22.5 rubber, the little axles that you are seeing are 6 lug and only 8,000lb capacity. They tend to wear out faster than the larger axles. Mack had a dump truck in Vegas 2 year's ago with 18,000lb lift axles and 385 super single tire's, was spec'd for an East coast state. Hope this answer's your question?
Cheer's, Neil.
