Old 06-02-2013, 10:42 AM
Default Re: Kenworth 850 Off Highway
Yes Steve, same as the first one except on mine the axles enter the housing and slip into the side gears. I don't think I could make what you're using work in these rear ends so I will try to upgrade the plastic case to aluminum. If that doesn't work then I will make new diffs in the fall...
Thanks for the help!
