Old 10-11-2013, 11:12 PM
Supermario's Avatar
Default Re: I have a servo gone mad!???
Originally Posted by oztruck View Post
Looks like the servo has died. But to eliminate the RX swap the 2 servo leads on the valve body. If the same servo is giving trouble after you have switched leads then it is the servo but if another servo has the problem then it is the RX.
Hope that helps.
Diagnosis confirmed. Thanks Chris. It's the servo. I'm surprised though. The servos are not original plastic gear type. I upgraded to metal gear servos after the boom function stripped a gear and there's not that much run time on them...
I still have one original servo that works and have installed in the mean time
Originally Posted by doodlebug View Post
Maybe you could convert the servo, to continuous rotation,
For another project.
Cheers, Neil.
Maybe run a shaker table or screening plant the way it is right now. Lol
Seeing as I'm just starting out in this hobby, I need to build up my various odds n ends parts inventory.Once I take it apart and see what's up, I'm sure I'll find a use for it. Maybe windshield wipers!
Mario
