Old 10-19-2013, 06:58 PM
tracksntreadslou's Avatar
Default Re: Brushless advice
Thanks AP ..Yes I do have the mount and dog drive ..its a little differend couple system then my older pumps ..this one doesnt have the rubber coupler in between the two but looks as it will work fine ...the shaft size is .125 or 3.175 mm so that should help when picking one out ..Wonder if the motor mounting holes are all pretty standard as well
Lmackattack I think why Leimbach offers it is that it supplies a higher speed and a bit more flow for the upgrade ..on their page its recommends not to run it at full speed for long periods .. For some reason i had though it help with longer run times as well but may be wrong
Blender .Thanks ..that looks pretty slick very small footprint indeed ..Thanks for the tip on KV ..starting to understand a bit more now ..
