Thread: Bruder CAT 320
Old 11-26-2013, 10:01 AM
cosworth34677's Avatar
Default Re: Bruder CAT 320
well i found the if you use magons stuff he uses a rod and set screw. i re drilled the holes and put m4 bolts thought everything. also i would keep the mounting points the same. i have found that im starting to need to replace some of the plastic parts with metal ones
