Old 12-20-2013, 06:05 PM
22fatcat's Avatar
22fatcat 22fatcat is offline
22fatcat is on a distinguished road
Default King hauler Dump Truck
I just wanted to show off a project that I am working on a King hauler dump truck I know that its not any new but I am working on a lift mechanism that I hope I will work without a lot of modification to the truck.It is using a Firgelli L12 servo that works real nice until you put weight in the box, so I think that I will have to use a gearmotor and a screw. Any suggestions are welcome Thanks in advance.
Paul T.[IMG][/IMG][IMG][/IMG]
Old 12-20-2013, 06:35 PM
blitzk's Avatar
blitzk blitzk is offline
blitzk is on a distinguished road
Default Re: King hauler Dump Truck
I talked to Ian at Firgelli a little while back about the lack of power from the L-12 and he said they are coming out with a L-16 with a lot more power. He was nice enough to send me a couple prototypes of this and WOW, what a difference!!! He said they should be on the market within a couple months, they will be well worth the wait and I think they should be enough power to dump a load of dirt.(Ian told me each one should be able to lift 40lbs.)
Old 12-20-2013, 06:36 PM
blitzk's Avatar
By the way, nice build so far!! Looks really good.
Old 12-20-2013, 06:46 PM
22fatcat's Avatar
Thank You, I was on the Firgelli web site today and I noticed the L16 they are 12 volt. I was hoping to run this on a regular 7.2 battery pack. Ian is a real nice guy he sent me some parts to repair that servo in the picture.
Old 12-20-2013, 07:02 PM
blitzk's Avatar
The L-16 is 12 volt but I run mine on my wrecker with a 7.2 volt battery and it works fine. The new L-16 prototype will plug right in to your receiver. Those are the ones that are coming on the market in the next couple months. You are right, Ian is a very nice guy to deal with. I bought two of the L-16's, when I got them, noticed it was a five pin connection instead of 3 pin like a regular receiver plug. Called up Ian, by the next morning he emailed me to let me know he had built 2 prototypes for me and shipped them out to me that day!! Awesome dude!!!
Old 12-20-2013, 07:33 PM
22fatcat's Avatar
any pics of your wrecker?
Old 12-20-2013, 07:51 PM
blitzk's Avatar
It's not done yet but.....
Old 12-20-2013, 08:54 PM
cabs cabs is offline
cabs is on a distinguished road
looks cool man. When I hit the lottery I want Greg-losi to build me wrecker
Old 12-20-2013, 09:51 PM
JoseFL10-4's Avatar
JoseFL10-4 JoseFL10-4 is offline
JoseFL10-4 is on a distinguished road
HI, I hope to help you check this guy www.piggytaylor.com i have the same problem with my wrecker firgelli i change it. this guy sale a part to lift a ramp to bruder trailer do same work than the firgelli but lot more torque, part is about 10inch long contact him and tell about your project he can help you.
Old 12-21-2013, 11:05 AM
22fatcat's Avatar
Hey I like that, I have always liked tow trucks
Old 12-22-2013, 08:44 PM
22fatcat's Avatar
Here are some pics of the gear motor setup that I am going to use instead of the firgelli servo[IMG][/IMG][IMG][/IMG]
Old 12-24-2013, 10:50 AM
I like it!!!which engine you used to lift the dump? Rb35?
Old 12-24-2013, 02:16 PM
blitzk's Avatar
Looks good 22, does it lift a lot better than the actuator?
Old 12-24-2013, 08:43 PM
22fatcat's Avatar
yes it seems to lift very well, it's a little slow but i am no on the clock and there is no u joint to mess with. i am going to put set screws in so the bolts wont be sticking out.
Old 12-24-2013, 08:50 PM
22fatcat's Avatar
that motor is one that i had kicking around its probably from jameco or something it's about 100 rpm
Old 12-24-2013, 09:02 PM
22fatcat's Avatar
I spent some time on the paint over the last couple of days. The white and yellow is paint the orange and black is vinyl. Now I have to finish the box and it will be ready for work. The next project will be to finish my excavator that I started many years ago.
Old 12-25-2013, 12:23 AM
blitzk's Avatar
Looks good, I like the wide tires on the front.
Old 12-28-2013, 08:00 PM
Nice truck, and box. I like the color scheme. Did you lift the cab on this one? Looks to be sitting a little higher than usual. The scissors lift mechanism is nice. Home made, or something available through the net?
Old 12-28-2013, 10:25 PM
22fatcat's Avatar
Yes I did lift the cab i just flipped the angle brackets over. The scissor lift is one that I made, the parts were cut with a waterjet. I built a new box for it today the other one sat to high and I was not happy with my welds. i will post some pics of it soon. thanks for the comments.
Old 12-28-2013, 10:48 PM
22fatcat's Avatar
Here are some photos of the new box with the side rails. They still need some work to finish them up. The new box sits lower on the frame and the bottom edge is nice and sharp.[IMG][/IMG][IMG][IMG][/IMG][/IMG]
Tags
dump truck, firgelli, king hauler, tamiya
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
