Hello all,
i have started to build an american style truck and it can only be an Oldtimer. Therefore i have choiced a truck from the 50ies, Peterbilt 281, the same i have watched in the movie Duel. Components are 2 old driven axles from Wedico, front axle from Robbe and gearbox from Veroma. The other parts will be selfmade. Pete-281-001.jpg Pete-281-002.jpg Pete-281-003.jpg Pete-281-004.jpg Pete-281-005.jpg
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Hello all,
next parts: Pete-281-006.jpg Pete-281-007.JPG Pete-281-008.JPG Pete-281-009.jpg Pete-281-010.jpg
OOOOHHHH im watchin this one!!!
Hello all,
the driven axles: Wedico-Pendel-002.jpg Wedico-Pendel-003.jpg Wedico-Pendel-004.jpg Wedico-Pendel-010.JPG Wedico-Pendel-012.jpg
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 02-15-2014 at 04:19 PM. |
Thanks Chris
Hello all,
i must rebuild the side parts of the fenders new, because they were not correct. All the parts are in aluminum, screwed and glued Pete-281-014.jpg Pete-281-015.jpg Pete-281-016.jpg
looks great Wolfgang - Oldies pete - I like your style
you sir are a magician with your sheet metal skills. love to watch you work.....
louie |
You are off to a great start, Wolfgang! Making everything out of aluminum is quite ambitious, but I like that you are doing things that way.
Nathan |
Very cool....I like how you are Building your own leaf springs....can you give me some details...I would like to make my own for my trucks as the stock springs are very soft....
Hello all,
thanks for compliments, i will try my best
Hello all,
to rise the cab, on both sides and able to open. This is a perfect place for switching battery or charging socket. Pete-281-017.jpg Pete-281-018.JPG Pete-281-019.JPG
Thanks for the great idea and for sharing pics of your progress! Reg |
No Problem, Reg therefore exists a forum like this
hmmmm I may have to go buy a rake now...... awesome idea.
Loving the battery box
Hello all,
the other side of the stairs, i must build the part a Little more widther, because at the 1955 Pete they are the same width as the fenders. There are a lot of differences between the original 1955 model and the existing 1960 Pete. Pete-281-020.jpg Pete-281-021.jpg Pete-281-022.jpg Pete-281-023.jpg
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 02-18-2014 at 01:17 PM. |
Hello all,
i have found a pic and i think this must be from the real truck (damaged at the end of movie), in difference to the survived truck, the stairs has the same width like the fenders and the upper side of the frame behind the cab is closed Pete-281-885.jpg
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 02-18-2014 at 02:07 PM. |
Hello all,
fuel tank made in copper sheet (not ready) Pete-281-024.JPG Pete-281-025.JPG Pete-281-026.JPG
Best Regards Wolfgang To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Seilbagger; 02-22-2014 at 12:59 PM. |
| Currently Active Users Viewing This Thread: 23 (0 members and 23 guests) | |
| Thread Tools | |
| Display Modes | |
