Old 02-24-2014, 12:26 AM
Lmackattack's Avatar
Default Re: Mack M75SX
Looking good. Right truck for the right job....
was this the paint job your thinking of?....
Old 02-24-2014, 07:43 AM
Joe , I can get 2.5 ton (5000 lbs)in the dodge so a ton is level at the top of the wheel wells .
Mack , that's it where did you find the pic ? I've looked forever .
Old 02-24-2014, 10:33 AM
There was a thread on bigmacktrucks.com about the stars and stripes Mack's.
There also was a thread with all the real heavy off road Mack's think I had saved the pic after seeing it.
Old 03-14-2014, 07:29 PM
Reg will be proud not quite the right color but heck with it . I whant to do the bi-centenial paint but I'm going to build another , sooo
Old 03-14-2014, 07:33 PM
WOOOHOOO! It's about F*****G TIME! lol
Looks great to me Steve! Wish I was going to be at the upcoming show with you guys...
Old 03-14-2014, 07:35 PM
Looking good. I have seen these macks painted in many different colors, dark yellow,red, white...it's not like the traditional cats where 99% are all yellow.
Old 03-14-2014, 08:00 PM
the m45's and m35's at a quarry I use to haul out of had close to this color . then a m45 front cut off at a show in lititz PA (Mack days ATCA )I went to was sorta Allis Chalmers orange . yea colors all over the place
Reg , get on your private jet and come down
Old 03-16-2014, 10:35 PM
few more , need more paint . I got 1 can to test the color The store was closed today oh a lil grease on the cylinder rams werks wonders for masking
still got the grime to clean off the axles and shave a lil off the bottom of the beams
I'm going to finish the detail too finally gotta find some more mack emblems . I'm gonna rob the letters off a bruder for the front of the hood possibly the bulldog too
Old 03-17-2014, 05:35 AM
I've been using Vaseline for yrs to do this... get some on an area you wanted to paint, use a Q-tip soaked with lacquer thinner to wipe away a clean edge... I've even tried this method for curvy paint lines on plastic bodies with good results.
Do you use electrical cleaner to clean the grime away? I used a can of that to clean off the oily grime from my 850 after the cyl leaky mess all over the bottom of the stick & coupler... it was like it was steamed off.
Old 03-17-2014, 05:59 AM
Ether old trick I used when prepping oil pans for reinstall . Never had a leaky oil pan or timing cover yet I just can't get the same stuff I used years ago , seams to leave a bit of oily residue that I have to blow off . electrical cleaner is real good too , I just never have it when need it ether is always on hand this time a year. yes I may try the Vaseline in the Mack logo on the hubs , I want that to stand out a bit .
Old 03-20-2014, 09:57 PM
almost back together leaving the rims raw aluminum to have a break in color going back to the rc4wd tires just glue the back beads so they don't walk out under a load when turning For the fronts , I have some flexible foam from 3M to try , Just waiting on the applicator .
after thought , its funny to see paint on it
Old 03-20-2014, 10:05 PM
Looks great Steve!
Old 03-21-2014, 01:39 AM
RCTech9's Avatar
RCTech9 RCTech9 is offline
Looks good Steve!
RIP FGD 12-19-11
Old 03-21-2014, 11:45 AM
What an improvement over bare aluminum
Old 03-21-2014, 11:55 AM
steamer's Avatar
steamer steamer is offline
Steve, Looks great with some colour on it! Now all you need is some cherries on top and a siren to put out Magnesium fires with lots and lots of sand!!!
Rob
Old 03-21-2014, 01:16 PM
TRUCKMAKER's Avatar
Looks good Steve, I'm a big fan of Red! Also like the rims bare with the painted hubs.
Old 03-21-2014, 08:37 PM
Snochaser's Avatar
Definitely nice to see it painted. It's like a whole new model now huh?
Ben
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 03-23-2014, 09:42 PM
thanks guys
emblems (hat pins)
Old 03-24-2014, 03:36 PM
Did you make that emblem yourself on your big machinery?
Old 03-24-2014, 04:01 PM
I could. I have it drawn up same as the rear hubs . It's a hat pin , couldn't beat the price
