#261
Looking good. Right truck for the right job....
was this the paint job your thinking of?....
#262
Joe , I can get 2.5 ton (5000 lbs)in the dodge so a ton is level at the top of the wheel wells .
Mack , that's it where did you find the pic ? I've looked forever .
#263
There was a thread on bigmacktrucks.com about the stars and stripes Mack's. There also was a thread with all the real heavy off road Mack's think I had saved the pic after seeing it. |
#264
Reg will be proud
![]() not quite the right color but heck with it . I whant to do the bi-centenial paint but I'm going to build another , sooo ![]()
#265
WOOOHOOO! It's about F*****G TIME! lol
Looks great to me Steve! Wish I was going to be at the upcoming show with you guys... |
#266
Looking good. I have seen these macks painted in many different colors, dark yellow,red, white...it's not like the traditional cats where 99% are all yellow.
#267
![]() Reg , get on your private jet and come down
#268
few more , need more paint . I got 1 can to test the color
The store was closed today oh a lil grease on the cylinder rams werks wonders for masking ![]() ![]() ![]() still got the grime to clean off the axles and shave a lil off the bottom of the beams ![]() I'm going to finish the detail too finally gotta find some more mack emblems . I'm gonna rob the letters off a bruder for the front of the hood possibly the bulldog too
#269
![]() Do you use electrical cleaner to clean the grime away? I used a can of that to clean off the oily grime from my 850 after the cyl leaky mess all over the bottom of the stick & coupler... it was like it was steamed off.
#270
Ether old trick I used when prepping oil pans for reinstall . Never had a leaky oil pan or timing cover yet
I just can't get the same stuff I used years ago , seams to leave a bit of oily residue that I have to blow off . electrical cleaner is real good too , I just never have it when need it ether is always on hand this time a year. yes I may try the Vaseline in the Mack logo on the hubs , I want that to stand out a bit .
#271
almost back together
leaving the rims raw aluminum to have a break in color going back to the rc4wd tires just glue the back beads so they don't walk out under a load when turning For the fronts , I have some flexible foam from 3M to try , Just waiting on the applicator . ![]() after thought , its funny to see paint on it
#272
Looks great Steve!
#273
Looks good Steve!
RIP FGD 12-19-11 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#274
What an improvement over bare aluminum
#275
Steve, Looks great with some colour on it! Now all you need is some cherries on top and a siren to put out Magnesium fires with lots and lots of sand!!!
Rob |
#276
Looks good Steve, I'm a big fan of Red! Also like the rims bare with the painted hubs.
#277
Definitely nice to see it painted. It's like a whole new model now huh?
Ben
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
#278
thanks guys
emblems (hat pins)
#279
Did you make that emblem yourself on your big machinery?
#280
I could. I have it drawn up same as the rear hubs . It's a hat pin , couldn't beat the price
| Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
| Thread Tools | |
| Display Modes | |
