Old 08-16-2010, 08:15 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Default After all the planning - ya Just gotta have faith
First - INSPIRATION
Now the planning - make some sketches, calculate some measurements, think and measure twice.
Next - Materials - Beg - Barte - Swap - Buy
Next - laydown some lines ..... I like to use masking tape - easy to draw on and even easier to pull up and re-do
Old 08-16-2010, 08:59 PM
Izzy's Avatar
Backyard enginier
Default Re: After all the planning - ya Just gotta have faith
Next - CUT - I did a fair amount of thinking and re-thinking that I could pull it all off - then the time came to just DO IT!
Scared yet?????
Old 08-16-2010, 09:07 PM
JAMMER JAMMER is offline
Izzy that is a excellent build you caught that one to a T . Ed
Old 08-17-2010, 10:21 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Another IH??? You just about pulled your hair out with the last one!! Can't wait to see this one done!
Old 08-18-2010, 11:27 PM
Izzy's Avatar
Backyard enginier
Tc1cat - not another just posting for some new people to see........Although I have been contacted about doing another.
Old 08-21-2010, 10:22 PM
Hos1880's Avatar
Hos1880 Hos1880 is offline
Hos1880 will become famous soon enoughHos1880 will become famous soon enough
Izzy
the first one was awesome you should do another.
Merritt
Member of Central Plains Mini Truckers and Certified Army Nut
Old 08-23-2010, 05:54 PM
rHammer rHammer is offline
rHammer is on a distinguished road
It s a major modification.I can t wait to see it.
Old 08-23-2010, 08:44 PM
Izzy's Avatar
Backyard enginier
OK - so ya have it all cut up .... and then it hits ya - what in the H$(( did I just do - took a perfectly good cab and made it into scraps. HAve faith probie - it will work out.
Next step is to clean up the cut edges - sand a little on the glue surfaces - nothin to heavy just a little rouch up...
Then start glueing togther - use scrap pieces to "plate" the joint - this way if yo crash it shouldn't break as easy.....
Notice I used some other pieces to hold the base square - and made sure I was on a flat surface - we don't want the cab to be twisted...
I used .010 styrene on the joint for the sides - this allows it to be flexed into position later - theyre angled inward on an IH
.... more to come.....
Old 08-23-2010, 10:07 PM
Bodyman Bodyman is offline
Bodyman is on a distinguished road
nice truck, brings back memeries when i was a bodyman on the 1.1. years ago.
repaired hundreds after wrecked and did some recondition. front upper corners of the grill
used to crack in the corners.
nice job
steve
Old 08-25-2010, 12:50 PM
Mustang Mustang is offline
Mustang is on a distinguished road
After seeing your build in person at Indy, the pictures just do not do it justice. Truely outstanding work!
Old 09-05-2010, 09:48 AM
Izzy's Avatar
Backyard enginier
some more shots of that build I did last year
add some filler strips - her e i used round tube cut length wise in 1/4's
anything to help hold the filler in place...
Don't let the pictures fool ya - I layed nearly 4 layers of filler and then hand sanding each back off to get the curves, radius' and fillets just the way I wanted.
Hope this helps and encourages other fun builds!
Old 09-05-2010, 09:52 AM
Izzy's Avatar
Backyard enginier
I started with Tamiya green filler putty - ddn't like it
- costly for the amount you get
- resin leaked out from the actual filler - probably cause I didn't squeeze it out and hand mix
I switched over to staight old bondo - not sure this was a great choice as it seemed to shrink a tiny bit then after I had finally painted it - this could also be the primer an dthe top coat issues though
Here's a pic of here today
Old 09-05-2010, 09:58 AM
Brian in PA's Avatar
I'd rather be truckin'
Great build Chris! I just love this truck.
Brian
Old 09-05-2010, 08:17 PM
Yeah, I agree. This has to be one of the most ambitious rebuilds of a Tamiya that I have seen. It sure looks like an IH! I used to think these old trucks were ugly, but now they have a look that I can't ignore! You sure pulled it off. This project turned out awesome! Not that I don't like the colors you painted your IH, but I sure like the color combo of the one in your avatar! Now that thing looks sweet. Got any more pictures of both the 1:1 trucks and your model?
Old 09-06-2010, 09:47 AM
Izzy's Avatar
Backyard enginier
Thanks for the kind words guys - it's been a alot of fun to build - especially since she changes weekly - just ripped the MFU out - had enough.
Espeefan - I'll make a post for my fleet - Look for it. Might take soem pics today
Old 09-26-2010, 03:20 PM
jffhrvstr jffhrvstr is offline
jffhrvstr is on a distinguished road
That is such a cool truck, good job on the cab!!
Old 11-09-2010, 05:53 PM
you did an awesome job. whats next ?
Old 03-20-2011, 11:21 PM
Izzy's Avatar
Backyard enginier
Ssshhh - its a secret .... pics being collected and will share later......
Old 10-28-2012, 04:35 PM
Johnboy72 Johnboy72 is offline
Johnboy72 is on a distinguished road
Thank you for referring me to this thread. I've never worked with anything this scale. But if I do, I'll be hitting you up. Your ref is a Youtube favorite. The 400BC runs perfect in that truck.
Old 10-28-2012, 04:57 PM
sandfarmer's Avatar
sandfarmer sandfarmer is offline
sandfarmer is on a distinguished road
Izzy that reference truck is VERY close to the 1:1 I told you I had at one time only in a different color scheme, same length same exhaust and mine had a 400BC also. Beautiful!
