Old 11-13-2010, 12:49 AM
Tamiya Cowboy's Avatar
Default Re: Step by Step KH to Day Cab
Well I dont run antennas out of my cabs I run them threw my stacks Battery's I run Lipos not the monster sized stick packs and I put them between my frame rails on the underside of my deck plates.
Paul W. "Tamiya Cowboy"
Old 11-14-2010, 05:06 PM
Bigrigger's Avatar
Ok thanks Cowboy! That helps a lot.
Old 11-14-2010, 11:04 PM
Yep the batterys are really getting cheap and are much better than the old style stick pack check into them..
Old 11-25-2010, 03:02 AM
Longhair Longhair is offline
Longhair is on a distinguished road
What type of glue did you use to keep the styrene in place before using the filler?
Old 11-25-2010, 01:49 PM
I use only Mercury Glue Products they are the strongest CA's on the market. There CA even melts the plastic and also glues it together so it is more like a weld.
Old 11-25-2010, 01:58 PM
Many thanks
Old 12-03-2010, 10:49 PM
kamyoncu's Avatar
kamyoncu kamyoncu is offline
kamyoncu is on a distinguished road
I have a question about knife. Could you write or add a link about it ?
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade
Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade
MAN TGS 26.500 6X6 Wedico - Premacon
MACK Granite 8x6
Old 12-03-2010, 11:02 PM
All that is exato mini saw..
Old 12-04-2010, 12:22 AM
kamyoncu's Avatar
Thanks a lot for reply , tommorrow I am going to look it homedepot. It cutted much more better than Box cutter .
MACK Granite 8x6
Old 12-04-2010, 10:29 PM
Bigrigger's Avatar
Hey TC, where can you get styrene, and how do fillers work? Sorry for the dumb questions, but I hope to be building a daycab soon, and want to know cab and hood modding inside and out.
Old 12-05-2010, 05:21 AM
Dreamweaver's Avatar
Weaver Of Dreams
I'm not Paul... but If you don't have a local hobby shop that carries styrene then you can order it from Tower Hobbies. Here is the link to it.
The stuff is made by Evergreen Scale Models.
The Tower Hobbies Link
As for the filler, you need it to "finish" the body work. The type TC and a lot of the others (Me included, thanks to TC) is made by Evercoat.
You can find it at your local auto body supply place or here
Evercoat.com
The link above is the stuff you want, even though it says "Metal" this is the stuff you want. It's about $40-$45 per quart.
This is a two part filler (Glaze) DO NOT buy the cheaper one part "spot Putty's", the stuff shrinks and cracks and is designed to be used before a glaze any way. Just go right to the good stuff..
Hope this helps
-Mike
Mike "DREAMWEAVER" Johnson
Old 12-05-2010, 11:08 AM
Hey Mike Thanks Much for answering them questions for me I have been busy with Centrail Plains Club Members at my house this weekend we have been having a build weekend for close members that wanted to come over and use my shop Will post picks soon.
Mike answered all the questions perfectly only thing is I dont use ANY spot puddy I think it is all junk I do my body work all the way out then use High Build primer then finish primer to get body work perfect,
Old 12-05-2010, 06:24 PM
Weaver Of Dreams
No problem Paul, weren't you the one that told me to use the Evercoat?
-Mike
Old 12-05-2010, 08:33 PM
-Mike
Not sure Mike if I was? Good chance thou I use it everyday on plastics and fiberglass and I have never had a problem with shrinkage in the 7 years I have been using it daily it is great stuff..
Old 01-12-2011, 12:54 PM
Darkrider Darkrider is offline
Darkrider is on a distinguished road
Great how to!
Old 02-09-2011, 11:48 PM
rcman rcman is offline
rcman is on a distinguished road
yeah great how to paul. i was wondering about the putty i used some and it did shrink after it cured really well .. i have used automotive bondo and that has worked fine too.
Old 07-24-2017, 04:46 AM
The pics are all gone! Is it possible to make them appear again? I've a KH that I will be removing the sleeper from this winter. I have a idea what to do, but would be great to see how others have had success with their method(s).
