Old 10-15-2014, 01:01 PM
osikasculptor osikasculptor is offline
osikasculptor is on a distinguished road
Default Need a Track control switch for 4200 excavator
Sheared off left track control top pin on the radio that has a metal "spider arm" which controls the left track.
It is a three position spring loaded self centering switch that controls f/b movement on the tracks. Tried to solder in something similar looking I had but didn't work. (They are green colored and replaced dials on the stock radio I believe)
The company may not be able to get me one to replace it and wondered if anybody knows where to get one or a link to something just like it that will work the same way? (hate to get another radio just for this one switch Thanks guys!
Old 10-15-2014, 07:06 PM
doodlebug's Avatar
Default Re: Need a Track control switch for 4200 excavator
Post a picture, The switchcan be replaced.
Cheers, Neil.
Old 10-15-2014, 07:39 PM
Green working switch to right is for R track (next to red switch)
File Type: jpg Two way switch.jpg (157 Bytes, 215 views)
File Type: jpg P1010730 23-17-25.jpg (157 Bytes, 213 views)
Old 10-15-2014, 08:18 PM
Cooper's Avatar
Cooper Cooper is offline
Xbox, play station controllers. It's been a while since I did something similar. I had radio apart and found out my fix was just some jb weld to reattach lever arm. But if I'm not mistaken the potentiometers are ones used in gimbals but a metal plate screwed to radio housing keeps it to one axis. Only one axis hooked up. Like I said it's been a while since I was inside that radio but I remember scraping some old game controllers gimbals and set aside for a later date. Pretty sure the reason I did that was from seeing them in that radio. As I spent a lot of time looking for a dial pot that self centers, single axis and could not find. At leas that small.
If memory serves correct, .
Old 10-15-2014, 08:46 PM
It seems to be only a single axis self centering for forward neutral backward
File Type: jpg P1010730 23-17-25.jpg (157 Bytes, 212 views)
Old 10-15-2014, 09:32 PM
Cooper's Avatar
Don't know if it's on my end but I can't see the pics. (Bill and Steve are still fighting!!)
Old 10-15-2014, 10:34 PM
Tried another way with pictures..if not will try tomorrow..thanks guys!!!!
File Type: jpg Two way switch.jpg (157 Bytes, 206 views)
File Type: jpg P1010730 23-17-25.jpg (157 Bytes, 204 views)
Old 10-17-2014, 11:57 PM
Pics edited to show hopefully
Old 10-18-2014, 01:57 AM
Cooper's Avatar
Xbox
Old 10-18-2014, 01:59 AM
Cooper's Avatar
I have been looking around for a single axis potentiometer self centering but these 2axis are the only ones I can find. At least small. Lots of um but about size of a 50cent piece.
Old 11-26-2016, 05:47 PM
mcCracken15 mcCracken15 is offline
mcCracken15 is on a distinguished road
I hope someone can chime in cause I need to replace my duals with a couple of these switched and rc4wd cannot come up with them. They keep trying to send me the metal extensions for 70 bucks.
Old 11-28-2016, 12:28 AM
thebigo thebigo is offline
Maybe tough for you to fined, but I Took a piece of brass and drilled a whole in the end and glued it to the remaining piece in the radio. Though I am going to a spectrum radio and receivers for all my equipment R/C's.
