Old 03-05-2015, 07:14 PM
gismow's Avatar
gismow gismow is offline
Default Custom build Scania Hauler T580
Hi...
I'd like to show you my actual project.
The project bases on a standard kit of a Scania R620
But it will be modified to a T580 Hauler. Something like this:
The modifications will be made by streching the frame and all needed custom parts will be build of styrene.
Let me show you some pictures of the creation until the actual state.
First I assembled the needed standard parts on a longer frame (plus 10.5cm) just to get an overview about the final size.
Now the modification started. The upper part of the grill must be cut of.
The lower part of the cabine must be cut off.
The part I cutted of will not be thrown away, it will be the base of the to be modeled haule.
Greetinx
Peter
Old 03-05-2015, 07:19 PM
gismow's Avatar
Default Re: Custom build Scania Hauler T580
After that I started to build the splashboard (???)
As next part I started to create the side plates.
But now it's time to see the first glance of a hauler...
Greetinx
Peter
Old 03-05-2015, 07:28 PM
gismow's Avatar
Now it was the time to start to build the hood. Main challenge was to get the same curve in the edges as the bumber bar.
To get the same form of the edges for the hood I modified the deflectors
After that they were cut down and glued to the cabine part I cutted off. In addition I added some styrene plates to stabalize the hood and to form the hood sides.
Greetinx
Peter
Old 03-05-2015, 07:38 PM
gismow's Avatar
Next challenge was to build to upper part of the hood.
In addition I saw that the side plate was too short. I had to stretch it by 5mm.
Next step was to add the side parts of the hood.
Now I started the most hated part, sanding, sanding, sanding, sanding....
And that's the state after the first sanding...
A small video (click me softly)...
Greetinx
Peter
Old 03-05-2015, 07:44 PM
gismow's Avatar
After a while I noticed, that the space between cabine and fifth wheel is too large...
Two possible solutions:
- New frame 5cm shorter
- Fill the space with something...
I decided to follow the second solution...
LONGLINER !!!!!!!!
Greetinx
Peter
Old 03-05-2015, 07:50 PM
gismow's Avatar
Step two: The roof
This is the state not yet filled or sanded.
Next step was the second side plate
The actual state
Greetinx
Peter
Old 03-05-2015, 07:57 PM
gismow's Avatar
Next step was to fill the gap between the cabine and the side plates.
While they were drying, I started to make the air gaps in the hood...
The position of the middle parts
The first electric parts found their final position
Actual state all parts in place
Greetinx
Peter
Old 03-05-2015, 08:00 PM
TRUCKMAKER's Avatar
Wow,nice styrene work! Looking forward to more updates.
Old 03-05-2015, 08:02 PM
gismow's Avatar
Now I started to fill the parts.
Today I started to build two boxes to place the electric parts while the rest is drying after the second filling and sanding job.
OK, now you're up to date...
Good night...
Greetinx
Peter
Old 03-05-2015, 10:36 PM
flatdeck's Avatar
flatdeck flatdeck is offline
Amazing build .. Always like the "T" cab..... can n ot wait for the rest...
Wayne
Old 03-08-2015, 12:20 AM
Wow great re work :-) great modelling
Old 03-08-2015, 01:06 PM
gismow's Avatar
Hi,
two additions came to my truck.
1. The fifth wheel got an automatic mechanism to open it.
And a small video about the function.
2. The root got a bit of light.
Greetinx
Peter
Old 03-13-2015, 09:04 PM
gismow's Avatar
Hi,
let me show you the actual state in a video. It is temporary assembled.
*** Click me softly ***
Greetinx
Peter
Old 03-13-2015, 10:40 PM
djcrabtree's Avatar
djcrabtree djcrabtree is offline
djcrabtree is on a distinguished road
I'm really liking this scania buddy. You've done a nice job on the body work and looks very clean.
Old 03-15-2015, 06:11 PM
gismow's Avatar
Hi...
Today I started with the lights for my truck. A time ago I saw a truck having daytime running lights and I decided to have this also in my truck.
First I made the drilled the holes
After that I formed the fiber optic cables. They are surronded by a heat shrink tube.
At the end a LED is placed.
And that's it...
Greetinx
Peter
Old 03-15-2015, 06:49 PM
Roundabout Roundabout is offline
Roundabout is on a distinguished road
That gotta be the best scratch build T-cab I've seen not to mention the longliner part of it, looking good!
René
____________________________________________
Old 03-16-2015, 06:33 PM
Johns85mcss Johns85mcss is offline
Johns85mcss is on a distinguished road
Amazing build
Old 04-28-2015, 06:45 PM
gismow's Avatar
Hi...
Longer time ago since my last post, so let me give an overview what happened in the meantime.
The rear light have been extended fro 3 lights to 6 lights per side.
During the build a colleague showed me his new lowbar. It was amazing, so I decided to build an own lowbar. After searching some brass, I started to build.
After the form was made I decided to add some details and light.
Greetinx
Peter
Old 04-28-2015, 06:57 PM
gismow's Avatar
After some time of building with styrene and brass I'd like to change to the electrics again.
I started to build a new board to give the truck a more realistic behaviour. The main features are:
- Realistic speed up and engine brake behaviour
- Realistic brake behaviour with an emergency brake
- Realistic steer behaviour depending on the speed
- Slow steering if the truck is stopped
- Automatic cruise control feature
- Heavy load - The speed and brake is more slow in the same way as it happens with a heavy load on the trailer
- Gear mode (forward, neutral, backward)
- If gear mode changes, the truck stops automatically in a realistic way
- Providing a brake light and a reversing light
- steering up to 4 steered axle in correct propotional behaviour
After that I went back to the back lights, they got their LEDs.
The center board for the back lights
The center board to spread the lights for front and back
Greetinx
Peter
Old 04-28-2015, 07:01 PM
gismow's Avatar
Now it was the time to start painting
Greetinx
Peter
