Old 05-28-2015, 10:18 PM
Cossett's Avatar
Cossett Cossett is offline
On Leave
Question Toggle switch to MFU question
Has anyone used a small toggle switch or similar between the MFU power cable and the battery so the MfU can be left on and power on/off there truck with the toggle switch ?
As I want to put the MFU control box under the hood where it cant be seen ( above the servos ), the main board in the daycab with interior above it and the battery between the chassis rails witch just fits in,
In hind sight it probably would of been easier to hing the hood but the cab has only come back from the painters again and the MFU only arrived last week so I couldnt do a proper mock up of cab /MFU
Here is the toggle switch I want to use, its a little Q11 6 pin DPDT toggle switch capable of up to 12 volts
Cheers Tracy
Love my Kenworths
Old 05-29-2015, 12:06 AM
Trucker Al's Avatar
Trucker Al Trucker Al is offline
Trucker Al is on a distinguished road
Default Re: Toggle switch to MFU question
Tracy,
You can put a switch in series with the power wire but it MUST be a heave duty switch. I use a DPDT 5 amp DC contacts switch so I get a 10 amp capable circuit.
Old 06-01-2015, 05:06 AM
Cossett's Avatar
On Leave
Would this work the markings on the other side of the switch
2A 250 VAC
5A 120 VAC
Cheers Tracy
Love my Kenworths
Old 06-01-2015, 08:22 PM
Trucker Al's Avatar
Hi Tracy,
If that is a Double pole (can't tell from the photo) it should work..
Alan
Old 06-02-2015, 04:19 AM
Brel's Avatar
Brel Brel is offline
I have done this with all of my trucks it makes sure that the MFU is off whilst sitting on the shelf when not in use
2A 250 VAC
5A 120 VAC
Cheers Tracy
Yes Tracy that would work fine, it is the same type of switch I used in my trucks
